pedro the fisherman
- Oct 28, 2004
- 1
Hello all,<br />This is my first post and hoping you can help sorry if this question has been asked I searched but could not find. <br />My 140hp johnno has an overheating problem, from cold it will get up and plane but after<br />several mins at 1/2 to max revs the engine dies back to 1500rpm's and goes into limp home mode.<br /><br />The tell tail stream is quite strong but the 2 cylinders on the starboard side of the motor overheats. On land with the muffs on after several mins operation at idle you can not touch the r/h/s cylinders the cylinders on the left are warm as per normal operation. Could this be a<br />thermostat problem??<br /><br />And could any one advise what year my motor is,<br /><br />Regards<br /><br />Pete
