99% bolt-on swap. Everything will bolt up. There's a minor difference in the wiring harness, due to the ignition & the method of driving a tach; more on that later.
They are virtually the same motor, just tuned for power at different rpm ranges. The 85 is 94 cubic inches, the 115 is 97. The 85 has a stouter low & midrange (ie, pops up skiers better). The 85 has a nice top end, & you'd never know it was missing anything unless you ran it top-end versus top-end against a 115. I've run both in the water & on a test prop, and the 115 definitely has an animal scream on the top end that the 85 doesn't have - they'll turn typically 5400 on the test prop, versus the 85's 4800 rpm. The 85 is a little better on fuel, which you may appreciate as you've run a 115 for a while. In sum, you won't notice any difference except on the very top end.
If the 85 powerhead is bare, you'll be using the 115's ignition & harness, so there won't be ANY differences between the motors. If the 85 has it's ignition, complete with the powerpack, I'd recommend sticking with it as I think as times go by the points-based ones have held up better, and idle better.
The 85 runs a points-triggered ignition, while the 115 runs a sensor coil-triggered ignition. Both powerpacks are powered by 12V from the motor. If you do need to mix up the ignition parts, post back & we/I can guide you through it. If you do have a couple ignitions, don't toss the leftover one - keep it for spares or sell it on eBay. Worth $40-$100.
