new to me 6hp
Glad to find this place. I have a question about my new find. First let me tell you that I was running a almost like new 1965 5hp Evinrude Angler on my little V Bottom 10 ft boat. I got a Johnson 6hp a few days ago for my boat. Its a 1996 J6REDS that still has some of the sticker on the prop. Like new too. Johnson has the 8hp with the same specs as mine, and I was wondering since its just 2hp if it would be maybe just a carb change or jetting change without having to replace the reed valve assembly or exhaust. Also the 8hp runs 5000rpm to 6000 and mine is 4500rpm to 5500. So maybe a timing adjustment would give 500rpm. The boat is rated for a 7.5 way back in 1965. I now have R and N AND drive. The old one you needed to be pointed the right way before you fired it up. Have ran both in the barrel and there is more torque from this one so far. Just wandering if it was simple or not. 2HP will make a difference on my little bitty boat. Well that would be 3 total I guess. And yes, I will get me a bigger boat one day. LOL Thanks for any advise. I read back about 5 pages before I joined up and there is another guy with a Angler just like mine that was leaking some. Small world.
