Hi, I have a Johnson 200hp model: 200TL76S, I have install new sparks plugs, De-Carb. new coils, rectifier, I have sparks in all cylinder, compression is good but the motor is still miss firing, I'm only getting about 2000 rpm at full throttle, but I can go anywhere at idle speed, motor start right up when cold or hot, Im running out of option please any help I will really appreciated.<br />Thank you
