Starter solenoid question
Phil Miller
According to the testing instructions posted on this site in the FAQ section, if the top small post on the side gets power when you turn the key, but nothing happens, the solenoid is bad. Mine is hot, but nothing happens (no click, nothing). The thing is, I just bought it new yesterday. What are the chances I bought a new bad soleniod. A'm I missing something here?<br />Lennyloafer
rodbolt
Re: Starter solenoid question
hello<br /> if you have 12volts on one small post to ground does the other small post have a good ground connection. posting year and horsepower would be a big help cause then we could tell you which wire colors and whether or not your model uses a safty switch on the throttle.<br /> good luck and post more
DHPMARINE
lennyloafer,As you say one small post is getting battery +.Now you need the other small post to get battery - .This is done either directly to the block,or I think in your case thru a neutral safety switch.The switch could be out of adjustment,or it could be bad.<br />While possible,I've never had a new bad solenoid.<br /><br />DHP
Phil Miller
The neutral safety switch is in the gear box, right? I don't see one. I think someone wired past it and took it out years ago. Is this possible?<br />Lenny
phatmanmike
the nuetral safety switch is in the control box, where you do your shifting and trhottling, not in the gearbox.
Phil Miller
I meant the control box. But there's nothing in there except the starter switch and the push/pull forward & reverse switch, and I'm pretty sure that motor will start in gear. Think I've done that before.
stsmith
If you are getting 12v to the starter and its not turning try bench testing the starter.<br /><br />Smitty
