Searanger Perth
- Sep 5, 2004
- 8
Hi Guys<br /><br />While running my outboard off the hose at home the other day, i noticed the water coming out of the pee hole started to slow down, its still coming out but not as fast as normal, i took the engine cover off and noticed that the transparent tube joined to the pee hole that there was air bubbles in it along with water, does this indicate a worn impeller or maybe even defect on water pump? the engine is a 1979 model,also normally the water coming out of the pee hole is quite cool, on this occasion it was getting hot. thanx in advance for any help given.<br /><br />Regards<br /><br />Eddy
