I have 70HP Johnson that needs lower unit replaced for its been in water not trimmed for many years and metal is very thin and just terrible shape. I have removed all bolts (6 - total), and removed bolt from shift linkage (even cut through it since I could see it and get to it to be sure its not the problem). Anyhow, unit is loose and can be wiggled back and forth, nothing can be holding it on but main shaft. I can put it in forward, neutral, reverse and wiggle it all day long, but its not coming off. Has anyone ever heard of this problem. I understand that main shaft just slides into splines and unit should just drop off at this point. However not the case for me. Let me know if anything I should do or try. Motor runs good, but I must get lower unit replaced.
