I have just purchased my first boat, a 1960 12" Montgommery Wards Seaking V bottom with a 1956 Evinrude Sportwin 10 ( I have named her the Redneck Ranger). I bought it from a first time boat owner that had it for three months! When I got it the motor would turn over but not run. He told me that it ran like a top till he tried to "fine tune the idle". So I got it home rigged a stand and put a garbage can under it with water. I backed all the adjustments back down to uh zero I guess you would say, then increasing till I finally got it to run, When I got it running it smoked like you wouldnt believe more like a fog machine then a motor! I am using the fuel that he had mixed so I am assuming that he has way too much oil in the gas??????? also as it ran (remember I no nothing about outboards) the peehole for lack of a better term was just spitting out water I figured there would be a stream! Is this ok! Also the water in the can has a slight layer of oil on it! I only let it run a min or two because of the pee hole issue? and the smoke so it is probably a decent amount of oil for the running time! There are pictures in my yahoo profile if interested (dd_mopowar) I hope I have given enough info for you guys to help me out. This is my first post, in what I am sure will be a long list of idiot like questions such as I was told that putting a casting deck in a 12' v bottom wasnt a good idea is this true! I do plan to work on her all winter, and try to get her into good enough shape that she looks like A Ranger bass boat built in a trailer park! Thanks for your time
