  #1
Old March 14th, 2005, 03:27 PM
Andrec4016 Andrec4016 is offline
Default Evinrude 140 New head Gasket?
Newbee here so be gentle, Just bought a 83 19 ft Manatee cuddy with evinrude 83 v4 140hp E140TRLCTE previous owner had for some time and the last fall when he took it out it was running rought cutting out in idle, so he took it in thinking it may be time for a tune up, the mechanic said its not worth fixing and to buy a new engine because it had a scratch in the cylinder with low compression, the scratch or score was at the top of the cylinder not with in the piston and the last owner thinks it can be fixed by replacing the head gasket. any thoughts on this, waiting on shop manual to work on the engine..
  #2
Old March 14th, 2005, 03:32 PM
rodbolt rodbolt is offline
Default Re: Evinrude 140 New head Gasket?
most likly its blown up. head gaskets are cheap but if the cyl is scared it wont last very long. I hate it when they bring it in for a tune up. means the dang things broke. if I had a dollar for every time I hear all it needs is a little adjustment I would have retired some time ago.
  #3
Old March 14th, 2005, 03:33 PM
Laddies Laddies is offline
If it is not in the area that the rings travel he could be right, it depends on what caused the scratch, how deep it is and if the rings are damaged, good luck
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #4
Old March 14th, 2005, 03:39 PM
Solittle Solittle is offline
Andre - Did the mechanic do a compression check & if so post the results here? Did he pull the heads? If so can you post some pictures?Oh and WELCOME!
  #5
Old March 14th, 2005, 03:48 PM
I don't have the reads from the compression test I'm going to do the test myself and as the scratch I did see it, the location was the top of the cylinder head no way near the piston travel area, and no loud or weird noise came from the engine when on.. just cuts out on idle
  #6
Old March 24th, 2005, 05:38 PM
Well I'm back again.. funny here I am ready to do the compression test and I realized I don't have specs for the read.. I have the manual but it does not have anything on what the compression reading should be.. the engine is a E140TRLCTE 99.6 cu in disp looking for lbs
  #7
Old March 24th, 2005, 07:16 PM
no specs other than all must be within 10 psi of each other.
  #8
Old March 24th, 2005, 08:43 PM
G DANE G DANE is offline
If you find something around 125 - 135 everything is really fine, but over 100 and within 10-12 on all and it will run fine. They came out around 140 when broken in.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Replacing Head Gasket on 1988 40 HP Evinrude BondJmsBond Johnson & Evinrude Outboards 2 March 20th, 2007 11:09 AM
head gasket torque specs for '69 Evinrude 115 scott-k Johnson & Evinrude Outboards 2 June 29th, 2005 09:02 PM
Evinrude 1958 7 hp -head gasket seal ? twinsburg Johnson & Evinrude Outboards 4 May 19th, 2005 11:30 AM
Evinrude Head Gasket - Goo ? Qld_Kev Johnson & Evinrude Outboards 5 February 26th, 2005 02:09 PM
Evinrude 1980 60 HP 2 cylinders Info on Replace head gasket MadeCoolCom Johnson & Evinrude Outboards 10 October 12th, 2003 05:16 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
