55Crestliner
- Aug 31, 2004
- 192
Not sure if this is a boat question or a motor question, I'll try it here.<br /><br />I've seen alot of people here say that the Ventilation plate should be even with the bottom of the boat. I'm currently building a new transom, my Ventilation plate is a whole 3 inches low. <br /><br />My question - does this apply to the old Johnyrudes also? I ask because they have a plate that is just above the Ventilation plate, which covers the water intake passage for the water pump. This plate has about 4 3/32 or so holes in it. Should I still have this old of a motor up this high? Will these holes be sucking air into the water pump if they are above the flow of water? This picture is small, but it shows the cover plate, just above the Ventilation plate.<br /><br />
