Re: 1973 johnson 135hp telltale
Toward the top of #1 cylinder, and just behind the intake bypass cover there is a small soft plug. Drill a 1/8" hole in the center to pry it out. You can then tap this hole to 1/8" pipe thread, you don't even have to drill this hole out, Use a 1/8" pipe nipple which is the standard size for the tell-tale. Drill a hole in the lower motor pan for the discharge hose. The whole job should'nt take half an hour.
