I have a 1993 Johnson 150 Fast Strike outboard model# VJ150GLETG that I am having problems trying to get started. The motor is attached to a 1993 18 ft Dynatrak Ebbtide. The problems started a while back with the motor being hard to start up and once it was started you would try and give it some throttle to take off and it would die. This would go own for several minutes before it would finally take off and run. But once it sat shut-off for a period of time you would have to go thru the same process of getting it started. Yesterday, October 10 2004, a couple friends and I were putting the boat in to do some fishing. We got the boat in the water and went to try and start it up. I turned the key over and the starter kicked over but I never heard it engage with the flywheel to turn the engine over. We tried for about 1 hour trying to start it up but the starter would only whine. The tilt for the motor worked at the motor, on the throttle and at the bow of the boat but now they don't do anything when engaged and when you turn the key it doesn't do a thing but the battery still has a charge. Any suggetion would be greatly appreciated. Thanks for the help.
