I was wondering if a lower unit from a 1971 Johnson 20 hp will fit and work on a 1968 20 hp?
B Bearcamp Petty Officer 1st Class Joined May 21, 2003 Messages 341 Oct 5, 2004 #1 I was wondering if a lower unit from a 1971 Johnson 20 hp will fit and work on a 1968 20 hp?
OBJ Supreme Mariner Joined Dec 27, 2002 Messages 10,161 Oct 5, 2004 #2 Re: Lower unit swap from 1971 to 1968? Think it will Bear. Just check that the drive shaft splines are the same.
B Bearcamp Petty Officer 1st Class Joined May 21, 2003 Messages 341 Oct 5, 2004 #3 Re: Lower unit swap from 1971 to 1968? Ok, I will. Thanks.
Chinewalker Fleet Admiral Joined Aug 19, 2001 Messages 8,902 Oct 6, 2004 #4 Re: Lower unit swap from 1971 to 1968? Hi Bearcamp,<br /> Yes, they're an easy swap. Splines are identical....<br />- Scott
