drewsimpson
- Oct 1, 2004
- 2
The stator on my 35hp Johnson is rubbing the fly wheel when the engine is running. I recently replaced the stator. Not sure if it was rubbing the old stator, but may have been what caused it to go bad. Unfortunately, I don't have it anymore.<br />There is about 1/16" play between the brass/bronze race on the stator plate and the round aluminium part of the block on which it rides.<br /><br />If I push the stator plate to the port while engine is running, it stops the rubbing, and much quieter.<br /><br />My options: <br />1. Replace the stator plate ($80+).<br />2. Grind offending node of stator down until it doesn't hit (are stators ever out of round?).<br />3. Ping race to create a tighter fit.<br />4. Have brass added to race (I tried this, and welder couldn't get it to stick without melting down stator, which happened some trying).<br />5. Put a spring on port side to keep tension on stator(OK, that one is far fetched).<br /><br />Any information would be great,<br />Thanks,<br />Drew.
