  #1
Old March 3rd, 2005, 01:46 AM
Tinkerer Tinkerer is offline
Default What is optimum throttle setting for '67 60HP Evinrude V4
This is a thirsty beast.Assuming I want to go anywhere reasonably fast, I figure the best compromise on speed and fuel consumption is to get it up on the plane and keep just enough throttle on to keep it on the plane.I guess that the nearer I get to WOT the less efficient it gets and more fuel it consumes for less result.Anyone know?
  #2
Old March 3rd, 2005, 03:19 AM
Laddies Laddies is offline
Default Re: What is optimum throttle setting for '67 60HP Evinrude V4
Tinkerer, I hate to tell you but, that would be THIRSTY---Bob :o
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #3
Old March 3rd, 2005, 04:21 AM
rodbolt rodbolt is offline
having water skied with one of them beasts I think the average was 6 gallons an hour at idle and carry 3 tanks at all times man what a fuel hungry beast.
  #4
Old March 3rd, 2005, 04:42 AM
WillyBWright's Avatar
WillyBWright WillyBWright is offline
Smell our Dairy Air.
Give it full throttle until you're out of the hole, then back-off to about 7/8 throttle. You'll hear the motor get quieter, and you'll lose about 3mph over top speed. But that's about where they run their most efficient. Below 3/4 throttle they lose efficiency. The more solidly the boat is on plane, the less the motor has to work. Look at your wake. Big waves mean a lot of wasted energy. 6 gal/hr is about what I got. That's 10 min/gal.
__________________
Hey, Have you seen? They make Really Cool life preservers nowadays.
So "Looking Dorky" is no longer an excuse for not wearing one.
  #5
Old March 3rd, 2005, 05:00 PM
Thanks all.6 gal an hour is about right. Of course, only about half that is actually combusted.
  #6
Old March 4th, 2005, 01:29 PM
tabbott tabbott is offline
Where does the other half go?
  #7
Old March 4th, 2005, 09:10 PM
Quote:
Originally posted by tabbott: Where does the other half go?
Straight out the exhaust. I was joking about the quantity, but these ain't the most efficient internal combustion machine ever made.
  #8
Old March 4th, 2005, 10:51 PM
marinemech marinemech is offline
tinkerer is correct up to 1/2 fuel goes out of exhaustif you want to play with high speed jets you can lean out motor. i did this to a 1965 75 h.p. it worked' fuel mileage went way upfind out what jets are in carbs then reduce size by .010 try motor and increase size until you get a reasonable running motor.note:you may have to use choke to get boat on plane.you also run the risk of burning a piston.its up to you
  #9
Old March 5th, 2005, 03:19 AM
marinemechYou're tempting me.Given the amount of wasted fuel I think there's a bit of leeway before I'd burn a piston. Or maybe they need to be swimming in fuel to avoid holing one.If I had the knowledge I suspect that the trick might be to work out how to change the petrol / oil ratio as the jets change to keep it on the right side of lean. I'm thinking that a fluid of a given viscosity will reach a point where it goes through a smaller hole slower than a bigger one, so when that point is reached the viscosity has to be adjusted to allow the right flow rate. So maybe a 50:1 goes to a 60:1 to allow enough fuel to pass. If it's left at 50:1 less fuel will go through and the leaning effect of the smaller jet will be greater than just the effect of the smaller jet.I'm not explaining this well because I don't know enough to be clear, but maybe you can get my drift.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 evinrude 25 hp, throttle setting jwilkey84 Johnson & Evinrude Outboards 0 June 13th, 2006 02:28 PM
1966 Evinrude 60HP/Dead Spot in Throttle joemamma_222 Johnson & Evinrude Outboards 19 March 19th, 2004 12:12 PM
84 Evinrude 60hp carb throttle shaft schweg2 Johnson & Evinrude Outboards 0 January 28th, 2004 01:29 PM
1986 60hp Evinrude bogs out at 1/4 throttle or more Steve Hilsabeck Johnson & Evinrude Outboards 4 August 26th, 2003 06:21 PM
Evinrude optimum performance question Gary Chappie Johnson & Evinrude Outboards 7 June 24th, 2003 10:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
