Re: Is there a way ??? (Need and expert - Joe Reeves please?)
Well, here's the scoop...<br />I got the boat out yesterday, ran it about for awhile just to make some observations and I found that the "warm restart" problem doesn't seem to exist any more! That's right, I ran the boat all over the lake stopping and restarting a countless number of times and never once did it stall on acceleration or even bog or hesitate. I am pretty convinced the problem worked itself out by whatever happened two weeks ago when the choke primer lever was moved out from, and back to it's original position. So, no more bogging or stalling, I guess then, no more problems! I looked again very closely to underside of the stator and from what I could see it seemed fairly clean without any sticky crud oozing from it. A second look at the top of the voltage regulator doesn't really reveal anything new either. Infact the one drop of stuff I saw there was actually rather crusty rather than sticky. Perhaps it was something that dripped long ago and has now dried up. I definately will keep an eye on this stuff though. I will say, overall I am certainly glad that I did NOT spend the money on a 3-carb rebuild and instead waited the time for the problem to go away! I know, I know, this could all come back some day and most likely it will but if it's not broke there's nothing to fix. These are the typ of problems I can aford! Thank you Iboats, Joe, Everyone, for makeing that waiting time seem to pass by quickly!
