Re: Connecting a trim gauge?
if your using the standard omc control box there is a power point just below key switch<br />order harness 174732<br />under dash where trim plugs into harness there should be two wires<br />white with brown stripe is trim sender<br />black is sender ground<br />from harness 174732 three wires come out purple is switched power<br />black is ground <br /> grey is for tach<br /> connect trim gauge as follows<br />purple wire to "I"<br />black wires to "G"<br />white /brown to "s"<br />trim gaige should now work with key on
