JasonJ
- Aug 20, 2001
- 4,163
I just aqquired a 57 Johnson 5.5 horse motor, with tank, for $60. The tank, other than needing a fresh paint job, is perfect. The motor, other than also needing a fresh paint job, runs. I ran it for awhile, and after making sure it ran (had to fiddle with mixture jets and replace that washer that goes around the main jet), it was running pretty good. I could not get it to idle very low though, but a quick adjustment of the points helped that. I then cleaned it, it was oily and nasty, and went to run it again and it wouldn't run worth a squat unless it was near wot. I knew I must have got water up in the ignition system, so I pulled the flywheel to blow the water out. The coils are badly cracked, parts of the sheathing falling off. My question is, since they do work, can I resheath them in epoxy, or should I quit being a cheap arse and just buy a new set. My thoughts are, it can't hurt to try. If it doesn't work, I'll just pop for a new set. Anyone ever done this?
