garman1986
- Sep 14, 2004
- 1
Hello this is my 1st posting...have enjoyed all the knowledge here. I have a 1988 30hp Johnson that started to misfires at the end of the last season. On acceleration it seems to be dropping a cylinder but only depends on where i put the throttle position. When it starts missing if I back off slightly it will smooth out, if I increase the throttle it missfires. It has even started to run poorly at idle. When I run the engine in a barrel at idle it is smooth most times but as I bring the throttle up in neutral a little bit it starts this "kicking" or "bucking" like a misfire. Compression is 100lbs both cylinders.I have changed the plugs QL77JC4. Replaced one igition coil as the lower cylinder spark plug felt cool and I thought maybe it was misfiring. I have installed a carb kit including float. I checked the fuel pump for output...good stream. I also checked the fuel pump on the vacuum side to see if it was leaking...no leak. This engine has a manual primer but it seems to be not leaking. I ran combustion chamber cleaner through the engine. Any ideas would be helpful. Thanks..Model number is CJ30TELCCE.
