The pistons do fit rather loosely in the bore compared to most anything else. It's kinda hard to tell if it's escessive because it always seems to be.
You can add a pee hole. All you need is about 16" of speedometer or aquarium hose and a brass fitting to fit into the block. Some have a 1/8" pipe plug on the top of the cylinder head that you can use to tap in. Other times you have to make your own place. Then it's just a matter of drilling a hole in the pan to stick the hose out of.
