madbanchee
- Aug 17, 2004
- 52
What is the compression supposed to be on a 1989 Evinrude 150 XP (E150STL)? I did a compression test (without warming the engine first) and all port side cylinders were 90 and starboard was 100. Just thinking about this now, I probably should have warmed the engine first, but I'll do it again later and compare my results. I will try the OMC EngineTune and check a third time. For now though, does anyone know what the compression should be and what it might mean when one whole side is lower than the other? The plugs all appear the same, a little blackened (sooty) around the metal part of the plug while the electrodes look mostly gray with a slight reddish tinge. They all seem dry and I haven't seen any metal depositson any of them.
