oil leak under flywheel 1960 40 hp evinrude
WillyBWright
Re: oil leak under flywheel 1960 40 hp evinrude
Welcome to iboats and yes it can.<br /><br />There was a special tool available thet screwed down into it and pulled it out. If you are unable to find a dealer that has one, you can drill a couple of tiny holes in it and screw a couple of tiny screws into them to help pry it out with a wire cutter. Try real hard to collect the drillings because any that fall inside are likely to damage the bearing. And be real careful not to damage the aluminum around it or the magneto plate won't turn freely.
daymaker
Thank you !You just made my day!Thanks for taking time to respond so quickly!You guys are the greatest!
