Re: 66 rude 40 hp hesistates
Sure could be something arcing over. Check spark plug leads for cracks,etc (ie, run at night and look).<br />Coils will have cracks in the insulation if they're bad. Only way to test is with a HV leak tester, which is not a common test instrument.<br /><br />When it's hesitating, do you have enough time to squirt some premix down the carb's throat to see if it picks up? Or bump the choke?
