I have a 16 ft sea dart with a 1975 70hp Johnson,the engine runs great in a barrel,it has 130 lbs compression in all three cylinders,it take at least 2 city blocks long for the boat to plane ,and for the engine to come to full rpm,once it gets to full rpm it runs great,and pushes the boat around 25 to 30 mph,the prop is a 13 x 19 ,someone told me the prop should be a 17,,the engine runs great at idle and at full rpm ,the problem is between the two and getting to full rpm.
