I am trying to find out if my motor has a shear pin or a slip clutch. any ideas?g
M moehead Cadet Joined Sep 6, 2004 Messages 7 Sep 7, 2004 #1 I am trying to find out if my motor has a shear pin or a slip clutch. any ideas?g
jimmbo Supreme Mariner Joined May 24, 2004 Messages 12,961 Sep 7, 2004 #2 Re: 1978 evinrude 35 hp Splined prop shaft means no shear pin. Most props for this motor will have a rubber hub.
G G DANE Commander Joined Nov 24, 2001 Messages 2,476 Sep 7, 2004 #3 Re: 1978 evinrude 35 hp It has a rubber hub, inside propeller hub. If you worry it is slipping, draw a line with some waterproof speedmarker, from the propshaft, crossing propnut and propellerhub. Go sailing. If the line is broken, hub spins.
