lakelover
- Mar 26, 2003
- 4,390
I removed the cylinder head on this motor to replace it; I recently decarbed it, but it still has a lot in there. I only found one obvious score mark on the lower cylinder. I'm not an expert but I thought the cyl's looked in pretty good shape other than this. What's the best way to remove the heavy carbon deposits? Will more decarbing do it or are more brutal means called for?<br />
<br /><br />The oil pool at the bottom is seafoam that I'd poured inside the cylinder earlier:<br />
<br /><br />
