robertmchenry
- Sep 4, 2004
- 2
Just bougtht an 11' alum. boat, 9.5hp Evinrude with trailer for $300.00! Clean setup with a really good running Evinrude model 9422s that I have found to be a 1964 9.5hp.<br /><br />Engine starts up w/o problems and appears to be a great running engine. I took it out Saturday & ran up & down the Miramack river here in Concord, NH.<br /><br />After pulling the boat out I decided to pickup some points, plug & some lower end oil.<br /><br />When I got home I drained the lower unit & found water and the oil to be a muddy black. I carefully removed the lower unit & inspected.<br /><br />The pump impeller appeared to be in good shape. Only questionable issue was the shaft that runs from the powerhead down to the lower unit. Shows some grooving on the lower end where I presume it sits in some kind of bearing. <br /><br />Reassembled and filled with clean oil. I did notice no seal of any king on the vent and drain plug so I installed a rubber o-ring on both. I also noitced oil around a loose screw that secures the lower half just below the prop. I tightened.<br /><br />Will take it out to the local pond & run a few laps & return home to reinspect for water. Will replace the oil in lower unit to make sure all water is out.<br /><br />"If" all looks good on the lower unit, meaning no new water should I be concerned with the wear on the lower shaft? <br /><br />If I find more water should I rebuild the lower unit, just replace seals or purchase a rebuilt lower unit?<br /><br />I'm new to outboards, I am picking up a set of points/condencers but I don't want to tear into the points until I'm sure how to set properly.<br /><br />I picked up an Intertec manual from the library but t's not too clear on how to set the points. It shows a plastic pointer tool to use to set the points but I don't have that tool. Also not shure where to set the advance plate so I'll hold off on the points till I get better guidance. Was able to replace the plugs.<br /><br />Thanks for the help & I'm glad I found this forum!<br /><br />Robert McHenry<br />Concord, NH
