Johnson 50HP power tilt
rmyette
My 1984 Johnson 50 HP power trim and tilt tilted up and will not go down. Battery is not the problem. Is the throttle mounted switch a likely place to start searching for a cause?<br /><br />Thanks,<br />Earthquake
D
DJ
Guest
Re: Johnson 50HP power tilt
Looki for the relays. They may be in a box mounted near the stern of the boat. You can track them down by listening for clicking when activated. <br /><br />When you find them, switch them and see if the problem reverses itself.
