Hi, I just bough a 1976 Johnson 200hp with a Grady-white WA boat, very nice condition, my question is: the motor it is not throwing water thru the pee hole, the water is coming out thru 2 holes on the back of the motor, the water is coming out with pressure and hot, however the motor temperature it is normal. Is this ok for a 1976 Seahorse Johnson, or I will have to remove the lower unit and change the impeller? Any help I will really appreciated.<br />Thank you
