outboardkiwi
- Aug 19, 2004
- 34
Heres an interesting question. While checking the timing on my 1989 V4 Johnson 90HP per the Joe Reeves cranking method I connected my timing light inductive pick-up to #1 lead with the arrow on the pick-up pointing towards the spark plug(tester 7/16) as I normally do when checking the timing on automotive engines but it would only work occasionally or sometimes not all, upon turning the inductive pick-up around so the arrow was now facing the coil it worked fine. Do you think the polarity of the spark is different or the voltage with copper conductor leads to high for the pick-up? Anything to worry about.<br />By the way I tried it on my car and it work fines either way.
