billy -
I agree with Fucci sorta - Impeller - definately, complete water pump - only if needed, fuel pump screen - clean/replace as needed. Might be a good time to add an in-line fuel filter/water seperator if you don't have one.
If your motor is running fine I would recommend that you leave the carbs alone. It is the old "if it ain't broke --------". Also give some thought to changing the gear oil (new gaskets on the fill/drain plugs), spark plugs, grease all fittings (& prop shaft) & you should be ready for the new season.
