Not getting any sparks, any reccomendations? Should the mag assembly be replaced? If I remove it, does the timing need to be redone?<br /><br />Thanks in advance!
i am assumeing you have a belt drive distributor<br />make sure belt is actually turn dist.<br />if not screws under flywheel may have come out<br />verify belt timing.if dist. is turning test coil and change points and rotor point part no.580290<br />rotor no.580256
