can anyone tell me, if i have a problem with my stator?<br />first: i have no dva voltmeter but a digital multimeter<br />if i put the black lead of the multimeter to the engineground an the red lead to eatch wire of the 6 pin connector i can see voltage when i crank the engine.<br />manual means there should be no voltage.<br />bought a new stator and it is the same.<br /><br />could it be the wrong voltage tester?<br /><br />or do i have an another problem<br /><br />need help<br />thank you <br />andy from germany
