Okay, now that I have fixed the carberator problem somethin new pops up. I will be running at WOT (5200 RPM)40 1994 HP evenrude TE model. Everything will be running fine just skimming along and all of a sudden the motor quits. No warning, and nothing obvious that I can tell. Just quits. Starts again fine and will run for a couple of minutes at WOT and then quits again. As it stands now, runs good at lower speeds and the problem has not migrated into the lower RPMs. Have to break out the manual again. Any suggestions??????????
