Hi. <br /> Recently bought this used motor which has been out in the elements(Canada) for the last three years. It's hard to start cold and sometimes hard to start warm. Sometimes it cranks fast(like a car), and sometimes slow(2 times/second). This can occur within a 2 minute period. Example - I can leave it for 10 minutes, come back, and it cranks fast and starts in 3-5 tries. It never starts right away when it's cold, and is sometimes hard to start if turned off(warm) and restarted 20 minutes later. I runs quite well, but will sometimes stall when idling. Should I replace the wires from the battery to the engine? Recommended wire guage? What is the minimum cranking amps required for this engine? Should I expect the engine to crank at the same rpm on every attempt to start, provided the battery is freshly charged? Can a starter solenoid be intermittant in such a way that it will pass sufficient current to the battery on one try and low current on the next try? <br /> Thanks for your help, CLK
