  #1
Old December 12th, 2004, 06:23 AM
mikelf mikelf is offline
Default Evinrude 50 stalls under load
1987 2 cylinder with CD2 ignitionengine runs smooth at idle but under load it stalls and completely shuts down spark to both plugs are steady but you really have to look hard to see it jump the plug Is this normal?I've gone through the fuel system,new fuel pump,line fitting and hoses,carbs removed and cleaned every part of the fuel system looked new cleanohm reading for the sensor coil and charge coil are in spec my manual instructs to set a spark tester at 1/2" gap my tester does not perform that way but I can't see this spark jumping a 1/2" gap any idea??Thanks
  #2
Old December 12th, 2004, 10:21 AM
steviecops steviecops is offline
Default Re: Evinrude 50 stalls under load
Because the plug gap is so small, you'd probably struggle to see it anyway. If you put a screwdriver (with an insulated handle!) in the plug cap, and hold it half an inch away from the block, the spark should jump the gap.Sounds like your idle speed may just be set too low. How does the engine run at other speeds?Good luckSteve
  #3
Old December 12th, 2004, 01:25 PM
fireman57 fireman57 is offline
Sounds like you have a powerpack that might have gone south. If you have a timing light you can hook it to each wire separately to test for spark. You can also put a nail in the plug wire and use insulated pliers to hold the wire half inch from the block. If the spark is yellow it is too weak to do any good. Must be bright blue.
  #4
Old December 13th, 2004, 02:39 AM
I made a adjustable spark tester and I can get a 3/8" steady spark from both,any wider and I lose it all together even at 3/8 it is a small flash not a popping sparktiming light flashes constant on both cylindersboth idle timing and advance are in specengine runs goods till it is loaded to plane the boat then it just shuts down,no spits or sputters just shuts off like you turned the key off I bypassed the kill switch and ignition switch with similar results thanks
  #5
Old December 13th, 2004, 02:45 AM
Change your powerpack.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 1984 70 HP stalls under Heavy load kynolan2183 Johnson & Evinrude Outboards 19 March 12th, 2007 01:34 PM
stalls under load cdspanky Non-Repair Outboard Discussions 2 May 15th, 2005 04:04 AM
stalls under load cdspanky Non-Repair Outboard Discussions 1 May 15th, 2005 04:03 AM
1980 Evinrude 100 h/p outboard -won't idle/stalls on load ian1 Johnson & Evinrude Outboards 1 July 29th, 2003 02:26 PM
stalls under load tom27 Johnson & Evinrude Outboards 2 July 22nd, 2003 03:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
