brokejohnie
- Aug 6, 2004
- 1
This motor was running two weeks ago, I started it long enough to see there was no water flow. After replacing the impellor and rewind spring in the recoil, I now have no spark. I have borrowed a fancy volt/amp/ohm/etc. tester and I was hoping someone might be able to direct me as to how I can figure out where my electrical system stops working. I have determined the kill switch is not the problem, but I am not sure how to check much else. I have lined up a friend with a good strong shoulder and I am ready to test, if that is possible.<br /><br />Thanks
