Has anyone seen this problem before?? About 2 hours into our boating day, I pushed forward on the throttle cable and nothing happened. Upon further inspection, I found that the cable end that hooks to the throttle lever (by the steering wheel) was VERY hot and had come apart. I could only throttle back in. When I got back home, while replacing the cable, I noticed that the other end that is hooked to the throttle on the engine was melted to the silver clamp that holds the cable on. Anyone know why this could have happened? I just replace the cable and don't won't this to happen again. Thanks
