I fogged and put away this '79 100hp Johnson sometime in january after doing some minor work motor work. She ran and idled good in a tank. Now I just put it on a boat and lo and behold she leaks hydraulic oil right around the rams of the trim cylinders. Can I just raise the motor and lock it up, lower the trim rams and remove the trim cylinder caps and replace the seals and or o-rings? The trim operates just fine and I just wants to get this boat on the water... thanks
