Hello, i'm a dutchman who wants to know if it is possible if someone can tell me how old my engine can be. The number on the "freeze" plate is G2612400. Its the only number i can find on the engine.Regards
Hello.I am one of those crazy Americans who understands and speaks Dutch (spent too much time in Amsterdam).Je moet ons het indentificatie nummer geven.Did is te vinden op de clamp waarmee je de motor aan de boot verbind(aan de bovenkant of de zijkant.Het serie nummer verteld mij dat het waarschijnlijk van de mid tot late tachtiger jaren is.Antwoordt in het engels,dan krijg je meer reacties.
Hey Rolmops??I know that you need the id number. But that's the problem! The only place i forgot to look is under the flywheel (vliegwiel) The plate on the bracket is gone...
Originally posted by DHPMARINE: Just a quick question about G2612400.Are you sure about this number?I normally can trace it,but am having difficulty.DHP
Hello DHP,I wonder if you can help me to identfy my engine.you did not give me any reply!regards...
