water_walter
- Aug 1, 2004
- 2
200hours on the the unit.<br />My engine slips out of forward gear after running flat out (5000rpm) for about 25 mins. After it has popped out of gear it will continue to stay out of gear until I return it to neutral. If I then put in forward and run at low rpm (2000) it will stay in gear. But if I try to increase rpm quickly it will jump out again.It seems to be temperature related because if I let it sit for about an hour, it will run good up to 5000rpm for about 20mins again. A local dealer replaced the complete gear assembly, there was no improvement. They are stumped. Does any one have any ideas.
