Re: Johnson Problem
Beringersd,<br /><br />Like Bubbakat said, that drain plug is pretty common. You could probably find it on iboats if you search around for it.<br /><br />As far as cleaning the carb goes, other people might disagree but a lot of people think that using spray cleaner is as good as taking the thing apart and letting it soak in gas. You can buy carb cleaner at any auto parts store. Follow the directions on the can. It's going to get VERY smokeie and it'll shoot gunk out of the exhaust so don't do it near the house.<br /><br />Make sure to run your motor on "muffs" any time it's out of the water.<br /><br />Also, it's a good idea to buy a manual for your motor to help you identify parts and troubleshoot future problems. They arn't very much and you can buy them on iboats also.<br /><br />Let us know what happens!
