Hey Guys<br />I have a Johnson 1959 10Hp Seahorse QD-20<br />I have serviced as much as i can do on this..<br />The carb,gears..etc..<br />I checked the impeller, and it seemed in fine condition, so i re-installed it rotating the driveshaft clockwise like the manual says..<br />Put the whole lower unit back, and gave it a run..<br />It started eventually..However I was nervous about the water pump,as they state in the manual that 5 seconds with no water can cause damage...(Oh I had a water clamp with a hose connected)..<br />However the manual does not say where water must come out...?<br />So i ran it for 10 sec or so..But then in the area of the top of the drive shaft was getting hot.So i stopped it..The manual refers to a flushette window....???WHat is that...?<br />And shoud water be coming out of the hole half way up the drive shaft...?<br />Is my impeller installed right...?<br />Any help would be greatly appreciated...
<br />Thanks<br />Roy
