At the end of last year, I was unable to start my 1995 115HP TurboJet. I installed a primer bulb on the gas supply and the engine would start. But now the engine will "hesitate" at mainly higher RPM's. The engine will slow down and then kick in again and on and on. Everyonce in a while it will keep going for 2-3 minutes without hesitation.<br /><br />I also installed a new VRO unit to see if that was the problem with no luck.<br /><br />The primer bulb loses "hardness" during the higher RPM's -- after I pump up the bulb, then the engine seems to run ok for a few minutes.<br /><br />Any ideas?<br /><br />Thanks for your help.
