Re: 1960 Erude Starting
There are a few places for fuses for different attachments. If your is mechanical shift (has a lever on the side), then it doesn't use most of them. You could have a bad solenoid, switch, or something's wrong with the safety switch. There are two mercury switches attached to a gear on the throttle linkage where the linkage goes thru the lower pan. One is for an ignition cutout to prevent run-on when you bring the throttle down fast, and the other prevents starting if the throttle lever is sitting too fast. That was the early equivalent to a neutral safety switch. The wires to those are probably broken by now. Or maybe the idle is adjusted too high and you can't throttle it down far enough to make contact thru the mercury switch.
