phatmanmike
- Oct 24, 2003
- 3,869
hello friends!
<br /><br />1988 14hp which is identical to 9.9/15, just has different lower unit.<br /><br />motor ran good before the decarb.but it had a idle problem, where it would stumble and sometimes die at lowest idle seting if i let go of the tiller throttle completly.<br /><br />before this, i had replaced plugs/wires,new fuel pump, and rebuilt t\he carb. this helped a lil.<br /><br />now, ever since i decarbed it last month, it will start and run for about 2 seconds, maybe, and die. and it takes about 15-20 pulls on the rope to start it.<br /><br />also, gas is now pouring out the front,top,left hole in carb when i squeze the bulb, which stays rock solid no matter what.<br /><br />if i look into the carb throat, i can see the gas puddled against the butterfly, and the plugs were covered in brown goo, almost like they were dipped in 10w40 motor oil! weird.<br /><br />anybody have any ideas?
