Re: 94 evenrude fires but won't stay running
Use a 7/16 spark gap tester and verify hot spark on all four. If not, Use manual to test ignition components (powerpack,stator,flywheel magnets,wires, timer base, etc..). Weak spark can be almost any or all of the above. Maybe someone who is more familiar can chime in with likely suspects. Coils and coil grounds also possible.<br />Good luck
