The plastic float chamber on one of my carbs on 1995 112 TSL cracked at a drain screw and was leaking. I went to dealer and ordered new float chamber. <br /><br />The new float chamber is aluminum (instead of plastic), shaped a little different inside, and my idle orifices and drain screws from my plastic one wont fit it. The bombardier part # is 392376 It matches up to the carb body fine.<br /><br />Dealer says its the only part he can get me. Is this correct? I havent encountered this problem before. Any help appreciated.
