Re: Testing OMC coils, points and condensors.
I take it you're thinking of your 2hp.<br /><br />The coil is virtually impossible to test, but 99% of the time it fails from cracks or 'moss' in the insulation which is plainly visible to the eye. Resistances should measure ~.3 ohms on the two low tension leads (primary) and around 4-7kohms on the high tension side to either low tension lead. The variance depends on temperature and which particular version of the 'standard' ignition coil you're dealing with.<br />The condensor can be tested with a multimeter that has a 'farad' capacitor testing range. Most meters don't have this feature. They should measure 'open' or infinite resistance on the resistance scale, but that doesn't tell you anything nearly conclusive. If you do have that meter, they should test as somewhere between 0.18uF and 0.30 uF. But this test isn't conclusive either since sometimes they fail only at high voltage.<br />The points if clean any shiney have to work. You could test their closed resistance which should be close to 0 ohms.
