I have a 1972 ( I think) 100HP Johnson motor. It will start right up with the chock and runs excellent until you start going about 3/4 throttle, then the motor will start missing and hesitating. I slow the boat down and shut the motor off. Motor is warmed up and to get it started again I need to chock it again. After it starts and it runs fine until 3/4 throttle. Put new plugs in it and supposedly carbs tuned. Any ideas what might cause this. I have also checked to see if the bulb is hard when starting to hesitating and it seems hard but not rock hard.
